AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Gavo
Noise when turning
Magnet    189
Fair point Cliff.
Will the Audi dealer guarantee that this repair will indeed eliminate the noise that bothers Gavin?
Even if they do - and I seriously doubt they would  ( perhaps Steve could comment on this from his dealership experience) - then of course Gavin would have to pay their rate for the job rather than take it elsewhere, IF he decides this the cure for his noise.
Share this post
Link to post
Gavo    2
Thanks both for your messages
thats what I'm more concernd of getting them repaired and it turns out not to be the issue. If I Consider getting them done I wouldn't be having them completed at Audi I would get a family member to do them for me all in would be around £100 includeing parts or I'm just going to wait untill the noise gets worser so it's Easyer  to diagnose. I'm just concerned as iv spent loads already and don't want to be wasteing more money. Atlest I know for one thing the parts changed I won't be changeing them again while I own the car
Share this post
Link to post
Gavo    2
If the Audi dealer guarantees this will eliminate the noise that is present then I'll be more than happy to have the work completed by them but I need to ask the question if it doesn't resolve the issue what then
Share this post
Link to post
Dan3222    107
Gavo mate, I really feel for you here. This has been a nightmare for you.
So I have been away for a few days with work etc and come back on here expecting you to have gotten to the bottom of this issue. I got excited for a second then thought well strut top mounts does not make sense. Magnet picked up on this straight away too, it really does not make sense at all.
You can do a basic test on the strut top mounts by the help of a friend. Park the car on grass, wetter the better. Don't have the engine on!! Get some one to turn the steering wheel from lock to lock while you have the bonnet up and both listen and feel the strut mounting point. The offending side will make a noise and maybe even clunk at either full lock. Hope this helps.
Going 0mph or 100mph won't make a difference to the noise of the strut top mounts and I am so sure you say that you can hear. Noise when traveling now, whether you are turning or not?
However, if it does indeed turn out to be these mounts then please accept my sincere appologies for offering my advice incorrectly. The dangers of reading and assuming we know what's wrong without actually driving someone's car.
keep us informed though mate.
Share this post
Link to post
Gavo    2
Thanks Dan for your message.
After reading magnets message it dose not make sense why they would say it was a top strut. Expecailly when i took the guy out and he indicated something on the rear drivers side. then now there saying top strut noisey when turning. but i dont know if it has any relation to the vibration i can feel through the passenger spring when turning lock to lock there is a vibration on the coil sping. When drivers side has been checked there no  vibration when turning. I will attempt to try your advise at some point tomorrow hopefully. I had a bad strut on my renault megan ( i know renault) and i could only hear that when going around 50 mph you would hear it wud wud wud. But this is only when turnng and pulling off when straighening the steering wheel the noise goes away.
As i mentioned everything else come up corrrectly on the dianostic & heath check i have attached the reports so everyone can see.
I am either going to get the struts replaced or wait for the issue to become much worser so its easyer to diagnose/locate - its a shame that i am located so far away from you guys because you seem to have more knowlage about the cars more than garages around here
Epson_08092017105529.pdf
Epson_08092017213520.pdf
Share this post
Link to post
Magnet    189
Hello Gavin,
Chances are I am going to bore you and the rest of the good folks on here!,  but I think we all feel for your plight here, and how you best go forward.
Basic questions which may add a bit more sense to this:-
Have they actually said to you that the cause of your noise is the wear in the upper suspension mounts?
or
Have they said that as part of the  Health Check   they have found wear in the upper suspension mounts?
Two very different questions, and the answers to them are really critical to the situation.
Prejudging your reply (which probably means you have to ask the dealer to explain again to be sure) it would not surprise me that this has been found as part of the health check, and not their quest to find the reason for the noise.
If that is the case, I would return to them and ask to see the technician who diagnosed thatvthe noise was associated with a suspected rear wheel bearing, and get him to have a proper look at this again and report back to you.
Share this post
Link to post
Gavo    2
Hi All,
I have requested to speak to the technician who worked on my car on Thursday last week to confirm a couple of details - Was the bad top strut found as part as the heath check or was it found as what was causing the noise.
Depending on this response will depend on what my actions are next. If they are unable to confirm if this is defiantly what my issue is then I will leave it until either something breaks or gets wroser, so the issue can be identified easier. but as you can see nothing else has flagged on the heath check apart from these top struts
Share this post
Link to post
Gavo    2
Hello All,
Just to give everyone an update. I have spoken to the technician that looked at my car last week and he is confident that is the issue but couldn't confirm it, I have told him I am not prepared to pay £654 based on confident as I have already spent a lot of money on this issue and do not want to continue to spend replacing parts if its not going to solve my issue, Anyway the guy at Audi was alright and what he has asked if I can re drop the car down to him and I take him out to hear this noise and if it needs to go in for another diagnostic just to guarantee that is the issue he said I will not be charged for another diagnostic.
So I am going to pop down there before the weekend and hopefully get this resolved and closed .
Share this post
Link to post
cliffcoggin    24
Best of luck Gavin. Let's hope Audi are prepared to be pinned down on the diagnosis.
Share this post
Link to post
Magnet    189
Indeed, all good luck to you Gavin. You certainly deserve it.
Sorry if I seem to be pinning down with this, but when I look back on your post of 31 Aug., you say the technician (who did a road  test with you?) said the noise was something to do with the driver's side rear, and it had to go in for further investigation - and the health check.
i just wondered whether the chap who said he thought the nose was coming from the back, was the same one who checked the car when it went in, and if he is the one you have been in touch with again, and will be looking at the car when they have it back in again.
Share this post
Link to post
Gavo    2
nah not at all gareth,
I can understand  exactly what your saying, and why this secondry check is important to ensure the correct parts are changed/looked out. as i have been advised it was possable rear baring then after check its top mounts so there gonna look at it can not ask for much more to be fair but i must admit this is a very intresting issue
Share this post
Link to post
