AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
JUDETUBE
SOFT TOP LEAK
I have a leak in my roof and have been told you can adjust and tighten the roof slightly forward to get a better seal
has anyone tried this or have a leak that they have managed to repair
Share this post
Link to post
Welcome to the forum Judith, you'll find the members on here are a friendly and helpful bunch :)
Where is the leak coming from?
Steve
Share this post
Link to post
both on the right and left hand sides where the roof joins the car through the plastic trim i have cleaned out the tubes and put in grease it is better but not completely cured.
Share this post
Link to post
Hmm, I'm unsure how to adjust the roof to be honest. I've looked online and YouTube but nothing is coming up that's useful.
Have you taken it to a garage to be looked at?
Share this post
Link to post
Hello Judith,
As a general rule of thumb those who reliably inform that things can be done, can usually actually do it. If they can't, then the advice is best treated as not being very useful.
In this case however, I would be tempted to believe that it probably can be, but would I adjust one? I most certainly would not, since these roofs normally have delicate micro switches etc. and you may end up with this roof simply not opening or closing properly, leave-alone leaking a bit!
Its difficult to fully grasp where this leak is - could you post a photo of the 'joint area' where the leak originates? A DIY bodge may be that you can add a strip of foam rubber , but very difficult to offer meaningful advice without looking/photo.
I see your location as Cradley. Is this Cradely Heath? If so, I might be able to point you towards a source reasonably priced advice/assistance if you are prepared to travel into S.Wales.
Share this post
Link to post
not taken it to the garage but i asked Audi yesterday and he said it may not be coming in from the corner area it may be along the front somewhere, and that is is difficult to find and may be quite expensive to fix!!
Share this post
Link to post
It sounds like they don't want to know!
When was the roof cleaned and treated with water proof protection?
Steve
Share this post
Link to post
To be fair I have only done it twice in 4 years, I will do it again when the weather improves, that may help
Share this post
Link to post
