Paulm81 Posted March 23, 2019 Share Posted March 23, 2019 The front wiper motor on the car stopped working yesterday, so i went to one of the local breakers for a 2nd hand replacement and the 1st one was different then 2nd wouldn’t work at all? So tried another motor and same nothing I’ve been to 4 breakers and 7 motors that look the same with same plug and no movement? Am I doing anything wrong? Does it need coded? Any help is appreciated thanks Quote Link to comment Share on other sites More sharing options...
Magnet Posted March 23, 2019 Share Posted March 23, 2019 Hello Paul, You could be right, it may need coding. Obviously, it is well beyond the bounds of probability that 7 wiper motors are at fault. I would now want to confirm that the motor is getting a supply voltage ( apologies if you have already confirmed this). If this were mine, having spent time and money in chasing around for 7 motors without success, I would now be at the point of investing an hour’s labour with a trusted local auto electrician. Kind regards, Gareth. 1 Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 23, 2019 Author Share Posted March 23, 2019 3 hours ago, Paulm81 said: The front wiper motor on the car stopped working yesterday, so i went to one of the local breakers for a 2nd hand replacement and the 1st one was different then 2nd wouldn’t work at all? So tried another motor and same nothing I’ve been to 4 breakers and 7 motors that look the same with same plug and no movement? Am I doing anything wrong? Does it need coded? Any help is appreciated thanks I’ve just found out that the wipers don’t work with the bonnet open so maybe one of the first 6 may have worked but the last one was the newest and cleanest looking out of them all and I actually fitted it properly and closed the bonnet and it only does intermittent cycle on full speed? i own a volt meter and test light if someone could help out would be appreciated as off the road due to scottish weather Quote Link to comment Share on other sites More sharing options...
Dan3222 Posted March 23, 2019 Share Posted March 23, 2019 I would guess the new motor needs coding as suggested by Magnet. everyday is a school day though, I never knew that they had introduced a cut of failsafe for wipers not working with bonnet open. 1 Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 10 hours ago, Dan3222 said: I would guess the new motor needs coding as suggested by Magnet. everyday is a school day though, I never knew that they had introduced a cut of failsafe for wipers not working with bonnet open. Does anyone know where and how to check if coding would work? Nearly 3 days car has been off the road due to the great scottish weather Quote Link to comment Share on other sites More sharing options...
Magnet Posted March 24, 2019 Share Posted March 24, 2019 Hi Paul, So you have now discovered the wipers and washers do not work with the bonnet open! Good isn’t it? Someone at VAG’s good idea, probably because due to one particular model’s wipers possibly catching on the edge of an open bonnet - or something! Re. a tutorial of using a meter. If this was my car, I would not be connecting a meter to anything on the car, if you are asking how to use a meter. These, like most other ‘modern’ cars, are ‘electronically sensitive’ and it is not advisable to go around connecting test lamps and the like unless you are competent. Appreciating the car is off the road, but I would now stick with my original suggestion and buy an hour’s services of a (mobile) auto electrician - it could be a lot cheaper in the long run. Kind regards, Gareth. p.s. Wiper stalk at fault? Could be. 1 Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 11 minutes ago, Magnet said: Hi Paul, So you have now discovered the wipers and washers do not work with the bonnet open! Good isn’t it? Someone at VAG’s good idea, probably because due to one particular model’s wipers possibly catching on the edge of an open bonnet - or something! Re. a tutorial of using a meter. If this was my car, I would not be connecting a meter to anything on the car, if you are asking how to use a meter. These, like most other ‘modern’ cars, are ‘electronically sensitive’ and it is not advisable to go around connecting test lamps and the like unless you are competent. Appreciating the car is off the road, but I would now stick with my original suggestion and buy an hour’s services of a (mobile) auto electrician - it could be a lot cheaper in the long run. Kind regards, Gareth. p.s. Wiper stalk at fault? Could be. Is the any audi specialist or auto spark on this forum near me by any chance?? Not sure what the fault is or was? Car went to a garage 1st time they started playing up and was told a wiper motor was the fault? I have tried a good few only problem is at the start the bonnet was open? a can see me selling it as nothing but problems the now 1 hour ago, Magnet said: Hi Paul, So you have now discovered the wipers and washers do not work with the bonnet open! Good isn’t it? Someone at VAG’s good idea, probably because due to one particular model’s wipers possibly catching on the edge of an open bonnet - or something! Re. a tutorial of using a meter. If this was my car, I would not be connecting a meter to anything on the car, if you are asking how to use a meter. These, like most other ‘modern’ cars, are ‘electronically sensitive’ and it is not advisable to go around connecting test lamps and the like unless you are competent. Appreciating the car is off the road, but I would now stick with my original suggestion and buy an hour’s services of a (mobile) auto electrician - it could be a lot cheaper in the long run. Kind regards, Gareth. p.s. Wiper stalk at fault? Could be. Just wondering, is there not aa way of checking with a volt meter if the motor and wiper stalk is faulty? I remember a friend showing me a wee trick to cheeck abs sensor?? im not a mechanic but do know wee bits and bobs and no scared to get dirty Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 Contacted the breakers yard and was told it was an a4 the motor was removed from? would that make a difference as the guy there said I could take it from a octavia, leon or golf? Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 Just a quick update 😊👍 cars fixed thank god!! Went back to breakers yard with the motor and mine with mechanism to compare properly, found an exact same in a 02 golf fitted it complete with wipers put the bonnet down and hey presto wipers are working again!!! like to thank everyone for all the help an advice 1 Quote Link to comment Share on other sites More sharing options...
Dan3222 Posted March 24, 2019 Share Posted March 24, 2019 That’s a result. More than likely because it was an exact copy the ecu recognised it and therefore did not need codeing for new part. 1 Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 Definitely dann and thank you, btw is there a trick to fit the scuttle pannel back properly?? As it’s sitting what a thought was correct but theres a gap between it and bottom of the windscreen? Quote Link to comment Share on other sites More sharing options...
Dan3222 Posted March 24, 2019 Share Posted March 24, 2019 Tbh not to sure, you might have to kinda hook it under the screen before putting screws in, some of these panels have a lip that sits under the screen. 1 Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 24, 2019 Author Share Posted March 24, 2019 6 minutes ago, Dan3222 said: Tbh not to sure, you might have to kinda hook it under the screen before putting screws in, some of these panels have a lip that sits under the screen. I’ve noticed the plastic trim on the bottom of the screen has a channel line if you get what i mean and on the scuttle panel theres a groove type bit that it sits in?? Just asking as mine has never sat right and when on my travels round the breakers yesterday I must have destroyed 3 scuttle panels trying to get the wiper motor out? And wondering if that what was causing my leak and soaking the carpet on passengers side? Quote Link to comment Share on other sites More sharing options...
Paulm81 Posted March 25, 2019 Author Share Posted March 25, 2019 Quick question completely off topic so I apologise just now, headlights on a3 8L can you split the lense off with out damaging it??? Quote Link to comment Share on other sites More sharing options...
