Looking for guidance where to find a power steering pipe for my 2002 TT, part number 8N2 422 8910
Roy762
Thanks Roy. Did your local Audi dealer say the part was obsolete? If so, did they suggest that there is a system whereby they can search/alert all dealers (UK and foreign?) to see if it might be available anywhere as unused stock.
TPS ? - the VAG specialist suppliers.
Partsfinder? - similar to 1st Choice.
Specialist publications such as Modern Classics (there are more).
Is there a TT Owner’s Club?
If all of this fails, then try local hydraulic hose suppliers ( commercial vehicle) who may/should  be able to make something up for you.
I have used TPS many times but on this occasion I am out of luck. I have a live searches still open on Partsfinder and 1st Choice. For the most part the pipe is metal with some flexible (rubber) sections. It failed at a fixing point due to corrosion (a common failure point in older cars) so I am advised. I believed this forum is linked to the UK TT Owners club?
Hello Roy,
Apologies for suggesting routes you have already been down, but I have also included are a couple of additional ideas.
If this were mine, I would be looking up commercial vehicle factors and paying them a visit armed with your defective pipe. They are likely to point you in the direction of hydraulic specialists who can probably remake the pipework for you.
  • 4 weeks later...
