Coolant leak - easy fix?
Danster
Hi all,
New member here and have ran into a problem with my 2.0 TFSI Black Edition S Tronic 3dr. There seems to be a leak somewhere, with my coolant empty 24H after filling it up. I have attached pictures of where I can see a pool of liquid and was just wondering if this is a common occurrence and an easy fix or if its worth taking to a mechanic.
(Don't really know my way around cars at all)
Thanks in advance
53 minutes ago, Danster said:
Hi all,
Thanks in advance
Id be getting it to a garage pronto as the rate of coolant loss is extensive.
  • Thanks 1
No coolant loss should be ignored, particularly one as bad as that, unless you want to ruin the engine.
As you don't know your way around cars I agree with Steve that it should be taken to a garage as soon as possible.
