yay 6 Posted June 13, 2022 Share Posted June 13, 2022 The LED headlights on my A6 C7 do not flash on to high beam when the stalk is pulled towards the steering column or switch to high beam when the stalk is pushed away. The blue headlight indicator icon does come up on the dash. OBD11 comes up with no errors. On OBD11 i went into Central Electrics and did an output test. The screenshots are below: Any ideas on what might bethe problem? Thanks Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 14, 2022 Share Posted June 14, 2022 The fact you've had to electrical faults in quick succession would make me wonder if your battery is in the way out. As a dieing battery can often cause all sorts of electrical issues. Also I wonder if the headlight switch could be causing a problem or the stalk itself. Quote Link to comment Share on other sites More sharing options...
yay 6 Posted December 1, 2022 Author Share Posted December 1, 2022 I had an electrical specialist check out the issue. He says the headlight switch and the stalk are fine. The fact that the blue icon lights up on the dash indicates that there could be an issue wuth the signal being sent but not received by the high beam leds. Has anyone come across a situation like this? Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 4, 2022 Share Posted December 4, 2022 On 12/1/2022 at 7:14 AM, yay 6 said: I had an electrical specialist check out the issue. He says the headlight switch and the stalk are fine. The fact that the blue icon lights up on the dash indicates that there could be an issue wuth the signal being sent but not received by the high beam leds. Has anyone come across a situation like this? What's the cure? A replacement sensor? Quote Link to comment Share on other sites More sharing options...
yay 6 Posted January 3, 2023 Author Share Posted January 3, 2023 Finally got it sorted. Turns out the headlights were not coded correctly. The technician downloaded the correct codes and all is well now! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 3, 2023 Share Posted January 3, 2023 6 hours ago, yay 6 said: Finally got it sorted. Turns out the headlights were not coded correctly. The technician downloaded the correct codes and all is well now! Glad you got sorted and with an easy fix 🙂 Quote Link to comment Share on other sites More sharing options...
Tigger Posted January 3, 2023 Share Posted January 3, 2023 Hi Denzil (again), Sorry, missed this the first time around... Having seen the screenshots now that would have been my first question - if the lights at high beam are reporting they're only using 25% of expected output/load then is the system expecting a high watt Halogen bulb rather than LEDs...? Are they coded correctly? (Were they switched out from Halogen to LED and not re-coded correctly?) But you have found the answer now - glad you got it sorted. Have you got used to the 'tyre rubbing' sound now at sharp turns/full lock...? (our first conversation some time ago) Best Regards, Tigger Quote Link to comment Share on other sites More sharing options...
yay 6 Posted January 3, 2023 Author Share Posted January 3, 2023 6 hours ago, Tigger said: Hi Denzil (again), Sorry, missed this the first time around... Having seen the screenshots now that would have been my first question - if the lights at high beam are reporting they're only using 25% of expected output/load then is the system expecting a high watt Halogen bulb rather than LEDs...? Are they coded correctly? (Were they switched out from Halogen to LED and not re-coded correctly?) But you have found the answer now - glad you got it sorted. Have you got used to the 'tyre rubbing' sound now at sharp turns/full lock...? (our first conversation some time ago) Best Regards, Tigger Hi Tigger, Thanks for the explanation - makes complete sense. Yes, I have got used to the sound and enjoying the car!! Quote Link to comment Share on other sites More sharing options...
