GLOW PLUG / ENGINE MANAGEMENT LIGHT
RoyC
I was coming back from shopping this morning and the car was very hesitant to accelerate away.
I got going but it wouldn't accelerate.
I looked on the dash and the glow plugs/engine management light was on.
I parked on my drive, unloaded the shopping and started the car up to put it in the garage and the light didn't come on, revved it up and still no warning light.
Anyone had this happen and how much did it cost to have repaired ?
Just done this scan.
SCAN 20 JUNE 22
Mon, 20 Jun 2022 12:26
Roy Clark (gragyroy@gmail.com)To:you Details
Monday,20,June,2022,12:02:02:31033
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WAUZZZ4F19N036857   License Plate: BK09 UPC
Mileage: 68140km-42340mi   Repair Order: 3
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
          62 72 76
VIN: WAUZZZ4F19N036857   Mileage: 68140km-42340miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (CAN)       Labels:. 059-907-401-CAN.clb
   Part No SW: 4F7 910 401 K    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17G000CG  0090
   Revision: 16H01---    Serial number:
   Coding: 010D002C02070128
   Shop #: WSC 18432 423 592680
   VCID: 2B5F28B68A7C09D74A-807E
   VINID: 9D196AAAA1160497800C62051CEFFC287A
4 Faults Found:
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
053286 - Please Check Fault Codes in Transmission Control Module
               U1026 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 007 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
001027 - EGR Valve (N18)
               P0403 - 001 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Mass Air / Rev.: 205.6 mg/str
                    Temperature: 52.2°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F5 910 157 H    HW: 01J 927 156 JG
   Component: V30 0AN 2.7lTDI RdW 0010
   Revision: --H05---    Serial number: 00000000000328
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2E5921A2B96E7CFF6D-807A
1 Fault Found:
006168 - Pressure Control Valve 2
               P1818 - 006 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100110
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 96 /min
                    RPM: 0 /min
                    (no units): 13.0
                    Torque: -48.0 Nm
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Component: ESP8 front      H03 0060
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0020876
   VCID: 6DDBE6AE74E8C7E714-8038
No fault code found.
Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601261827
   Coding: 0000147
   Shop #: WSC 02324 785 00200
   VCID: 254BDE8EEC983FA79C-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
   Component: KLIMABETAETIGUNGH30 0070
   Revision: 00000073    Serial number: 00000000601444
   Coding: 0001302
   VCID: 1D3BF66EC4C8F767C4-8048
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0013121
   Shop #: WSC 02335 785 00200
   VCID: 346D33CA5742562F1B-8060
   Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH04 0003
   Coding: 00146221
   Shop #: WSC 02335
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00111010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H47 0050
   Revision: 00000012
   VCID: 2143CA9E38B0D387E0-8074
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 30314236303630303033554A305234463053
   ASAM Dataset: EV_Airba10AURB4 001001
   ROD: EV_Airba10AURB4.rod
   VCID: 30653FDA6B5A6A0F7F-8064
   Crash sensor for side airbag: driver side:
   Serial number: 3574SRB400008495215.
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3584SRB40000849D397E
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 35152RB402J838NMVR2V
   Passenger side rear thorax airbag crash sensor:
   Serial number: 35252RB402P838NMV35H
   Crash sensor for front airbag: driver side:
   Serial number: 3554NRB40000491848A/
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564NRB4000049100D8W
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90055083440101
   Coding: 0102142
   VCID: 2757D48696942DB7AE-8072
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 B    HW: 4F0 920 983 B
   Component: KOMBIINSTR.   H06 0135
   Revision: 00000000    Serial number: AE940E1D8
   Coding: 2F57110502002700010401
   Shop #: WSC 02391 823 56573
   VCID: 2B5F28B64A7C09D74A-807E
Address 19: CAN Gateway (J533)       Labels:. 4F0-907-468.clb
   Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0024
   Revision: 4LA70021    Serial number: 2100L0910680F4
   Coding: 000303
   VCID: 326135D26D56581F09-8066
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140408501
Address 42: Door Elect, Driver (J386)       Labels:. 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Component: TSG FA        H11 0250
   Revision:             Serial number: 0000100632175
   Coding: 011F06205041410001
   VCID: 46897902F1DED4BFB5-8012
1 Fault Found:
02115 - Locking Unit for Central Locking
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 68128 km
                    Time Indication: 0
                    Date: 2010.01.14
                    Time: 20:17:13
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01166766660000
   Coding: 0140027
   VCID: 31633ADEA850630770-8064
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000002161
   Coding: 0F010000
   VCID: 2953D2BE40801BC7B8-807C
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000610073
   Coding: 0001103
   Shop #: WSC 02145 785 00200
   VCID: 5EB9B162894EAC7F9D-800A
Address 52: Door Elect, Pass. (J387)       Labels:. 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Component: TSG BF        H11 0250
   Revision:             Serial number: 0000100622308
   Coding: 011F06205C41410001
   VCID: 458B7E0ECCD8DFA7BC-8010
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000531
   VCID: 2143CA9EF8B0D387E0-8074
Address 55: Headlight Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 H
   Component: Dynamische LWR  H02 0010
   Revision: 00000001    Serial number:
   Coding: 0000003
   VCID: 3F876CE66E048577F6-806A
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H44 0020
   Revision: AB001007    Serial number: 341AQ097529712
   Coding: 010003010000000000
   VCID: 1C3DFB6A1FD2FE6F33-8048
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4E0 035 652 A    HW: 4E0 035 652
   Component: B-BN-EU       H47 0048
   Revision: --------    Serial number: 349A-097506098
   Coding: 010101010102EFFF67000F0DFF7F00030001
   Shop #: WSC 00779 210 97010
   VCID: 1F47CC660EC4E577D6-804A
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355AC091013090
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 H
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001249242
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 156
                    Mileage: 68134 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:06
             Freeze Frame:
                    Bin. Bits: 10000000 10100000
                    Bin. Bits: 00000000 00000111
                    Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388)       Labels:. 4F0-959-795.clb
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Component: TSG HL        H10 0251
   Revision:             Serial number: 0000100645651
   Coding: 010E04204041220001
   VCID: 438F6016C2ECE19792-8016
Address 72: Door, Rear Right (J389)       Labels:. 4F0-959-795.clb
   Component: TSG HR        H10 0251
   Revision:             Serial number: 0000100645097
Address 76: Park Assist        Labels: 4Fx-910-283.lbl
   Part No SW: 4L0 910 283 A    HW: 4L0 919 283 A
   Component: Parkhilfe 8-Kan H02 0400
   Revision: 00H02000    Serial number: 13630901502908
   Coding: 0201016
   VCID: 2855D7BA9B8A22CFA7-807C
End-------------------------(Elapsed Time: 02:58)--------------------------
                Address 01: Engine       Labels: 059-907-401-CAN.clb
Control Module Part Number: 4F7 910 401 K    HW: 4F0 907 401 E
  Component and/or Version: 2.7TDI EDC17G000CG  0090
           Software Coding: 010D002C02070128
            Work Shop Code: WSC 18432 423 592680
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
Control Module Part Number: 4F0 910 279 N    HW: 4F0 907 279
  Component and/or Version: ILM Fahrer      H22 0320
           Software Coding: 0013121
            Work Shop Code: WSC 02335 785 00200
           Additional Info: 4F2910113C  Wischer AudiC6  H10 0040   8K0910557   REGENLICHTSENSORH04 0003
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
                Address 42: Door Elect, Driver       Labels: 4F0-959-793.clb
Control Module Part Number: 4F0 959 793 R    HW: 8K0 959 793 D
  Component and/or Version: TSG FA        H11 0250
           Software Coding: 011F06205041410001
            Work Shop Code: WSC 02391 823 56573
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 68128 km
                    Time Indication: 0
                    Date: 2010.01.14
                    Time: 20:17:13
                Address 5F: Information Electr.       Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 4E0 035 652 A    HW: 4E0 035 652
  Component and/or Version: B-BN-EU       H47 0048
           Software Coding: 010101010102EFFF67000F0DFF7F00030001
            Work Shop Code: WSC 00779 210 97010
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 156
                    Mileage: 68134 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:06
             Freeze Frame:
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 68137 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 20:50:06
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 39.5 %
                    Lambda: 45.3 %
                    Temperature: 52.2°C
Control Module Part Number: 4F5 910 157 H    HW: 01J 927 156 JG
  Component and/or Version: V30 0AN 2.7lTDI RdW 0010
           Software Coding: 0000001
            Work Shop Code: WSC 02325 785 00200
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 96 /min
                    RPM: 0 /min
                    (no units): 13.0
                    Torque: -48.0 Nm
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 68132 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:00
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 68128 km
                    Time Indication: 0
                    Date: 2010.01.14
                    Time: 20:17:13
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 68128 km
                    Time Indication: 0
                    Date: 2010.01.14
                    Time: 20:17:13
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 156
                    Mileage: 68134 km
                    Time Indication: 0
                    Date: 2010.01.21
                    Time: 19:16:06
             Freeze Frame:
With the amount of electric faults logged I'm wondering how old the battery is? As a failing battery can flag up all sorts of electrical issues.
Is the car driving normally?
Hi has anybody else noticed the dates on these codes, the youngest is 2020 I don't think he has cleared the codes as suggested which would clear the memory capacity so it would only flag up current DTCs, if you don't clear the faults and the memory is full you won't get anything new.
Ah I'd missed that Steve!
I did clear the codes, or at least I thought I had.
Trouble is, I'm useless with this VCDS.
The battery was fitted 18 months ago,
Varta Silver I1 Heavy Duty Car Battery 12V 110AH
When the glow plug light came on yesterday, it went into limp mode.
The car has only done 42,000 miles.
As Steve has pointed out i think you'll need to clear the old fault codes. Make a note of them though. The do another scan.
Has it done it since?
I mean it could be an egr, dpf or turbo issue.
Was the battery coded to the car?
I think we can assume it's not the battery then in theory.
I haven't done anything else yet.
The car is hoisted up with no wheels on at the moment.
The pressure bleeder won't hold pressure so have ordered another, be here tomorrow.
I was having door locking / unlocking problems befor I changed the battery, it's ok now.
Hi you are not useless, what you have to do is if you have a later version of VCDS it will give the scanning options of non UDS or UDS click on UDS aggressive mode and scan again when its finished go back to controller and then click on erase DTCs it will ask you if you really want to do this press yes and it will clear them wait ten seconds then press done and wait for it for two seconds while it confirms then shut down, if you changed the battery and did not re code it the battery will quickly die through overcharging, I rather think the car does no real milage per year so I would treat it to a bottle of Wynns DPF cleaner and give it run then scan it again.
Thanks Stevey.
You are correct about no milage.
In lockdown, it didn't come out of the garage for 14 months and now it's back out only goes to the Asda once a week, unless I have a hospital appointment. Haha.
The battery is on charge 24/7.
Thanks Stevey.
Hi Roy time for a good run and a clear out I am afraid any diesel requires a good kicking every month or use of a proprietary fuel additive to keep them clean.
You think something as a dirty glow plug could cause it to go into limp mode ?
I thought fuel additives were to keep the injectors clean.
Hi not entirely, if you use Hydra Maximus or Archoil 6900 D synthesis it keeps the whole thing cleaner read up about them on line, irony think a dirty glow plug will cause your problem I think its either a sensor or a clogged EGR/DPF but you won't know until its been scanned again after you have cleared the existing codes.
Delete old codes and new scan is my first job after bleeding brakes, cant get into the car at the moment, the jacks are in the way of opening the doors.
My new Sealey pressure bleeder arrived today, it's got to go back because it won't hold any pressure.
I hope they don't say there has been brake fluid in it, how else would I find out it don't pressurize ?
DPF's ok, I've cleaned that a few times.
