Hi
Where and what fuse is suitable to power a dashcam
2 hours ago, Johnnym said:
Hi
Hi 10amp is about as high as you need to go, from memory I have nearly always used the fusebox under the cover on the left end of the dash, check the owners handbook for what fuse does what as you dont want to use an ABS/wipers fuse or anything that if it blows will leave you in poo creek, depending what the spec is of your model there may well be a spare fuse port in the box, thats what I did with my A6, the spare port was in the purple square, test for ignition live with meter.
