benweston Posted May 6, 2019 Share Posted May 6, 2019 Got some PCV hoses and an oil filter/cooler housing to replace which I need to remove the plastic upper inlet manifold to do. On every other car I've worked on, this has been a fairly simple task but this looks like a right pig – I can't work out how I can remove it without taking the whole front bumper off and removing the radiator?! I've downloaded the Haynes manual which is about as much use as a chocolate teapot. Am I missing something? I don't want to have to pay a VAG independent to do something that should be fairly simple but is this beyond possibility doing it on my driveway?! Quote Link to comment Share on other sites More sharing options...
