rzwood Posted 8 hours ago Posted 8 hours ago Hi, My S5 displayed an orange EPC light on the dash driving home from work. I was going to look it up when home, but then the car lost power and completely stopped. After a few fruitless attempts to start, it eventually started and I continued only for the same thing to happen within another mile. After several repeat incidents, I was able to get home. I have the Ross-Tech VCDS software so I hooked it up and these(below) were the faults listed: Is anyone able to diagnose the issue ? More relevant is whether it's fixable at the road side or do I need to have it towed to a garage ? Do I need an Audi dealer/specialist ? I'm not sure if the fault was triggered by the heat as it's been hot today in the UK(34C) and I could start the car after leaving it a few minutes. I don't think I should try to drive again for fear of the same fault. Any advice appreciated!! Thanks, Richard 6238 - Fuel Rail/System Pressure P0087 00 [00100000] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 2 Mileage: 121115 km Date: 2025.07.01 Time: 15:35:21 Engine speed: 1269.00 /min Normed load value: 29.8 % Vehicle speed: 65 km/h Coolant temperature: 96 ∞C Intake air temperature: 44 ∞C Ambient air pressure: 990 mbar Voltage terminal 30: 12.796 V Unlearning counter according OBD: 40 Engine speed: actual: 1248 /min MAF_ENVD: 375.84705 mg/stroke Coolant temperature (unfiltered): 94.50 ∞C FUEL_MASS_REQ_I_CTL_ENVD: 28.265625 FUP_ENVD: 1358.5177 hPa FUP_EFP_ENVD: 1363.83 hPa 16903 - Vapor Bubble Formation in Low-Pressure Fuel Circuit P125B 00 [00101100] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 8 Mileage: 121115 km Date: 2025.07.01 Time: 15:35:54 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 13 km/h Coolant temperature: 95 ∞C Intake air temperature: 51 ∞C Ambient air pressure: 990 mbar Voltage terminal 30: 12.898 V Unlearning counter according OBD: 40 Engine speed: actual: 0 /min MAF_ENVD: 0.00000 mg/stroke Coolant temperature (unfiltered): 92.25 ∞C Engine: operating status: ES FUP_EFP_ENVD: 2045.74 hPa Vehicle speed: actual: 8 km/h 11010 - Fuel Pump P3043 00 [00101100] - Mechanical Malfunction Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 6 Mileage: 121092 km Date: 2025.07.01 Time: 15:18:56 Engine speed: 2464.00 /min Normed load value: 56.9 % Vehicle speed: 20 km/h Coolant temperature: 96 ∞C Intake air temperature: 43 ∞C Ambient air pressure: 990 mbar Voltage terminal 30: 12.491 V Unlearning counter according OBD: 40 Engine speed: actual: 1184 /min MAF_ENVD: 76.25882 mg/stroke Coolant temperature (unfiltered): 93.00 ∞C Engine: operating status: PUC FUP_EFP_ENVD: 5455.31 hPa Vehicle speed: actual: 37 km/h 14812 - Fuel Pump P308D 00 [01100101] - RPM too Low Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Mileage: 121117 km Date: 2025.07.01 Time: 15:46:38 Engine speed: 1140.00 /min Normed load value: 7.8 % Vehicle speed: 35 km/h Coolant temperature: 94 ∞C Intake air temperature: 52 ∞C Ambient air pressure: 990 mbar Voltage terminal 30: 13.202 V Unlearning counter according OBD: 40 Engine speed: actual: 1120 /min MAF_ENVD: 92.60000 mg/stroke Coolant temperature (unfiltered): 94.50 ∞C Engine: operating status: PU FUP_EFP_ENVD: 4773.4 hPa Vehicle speed: actual: 35 km/h Readiness: 0000 0000
