Declanmc54 Posted May 17 Posted May 17 Hi folks i hope someone can help . I have a 2014 Audi a6 c7 sline ultra automatic intermitting stalling when about to take off and also when driving the car also has intermitting jerking as if for a split second fuel was cut. sometimes it can be ok for a week or so then other times it can happed 2 to 3 times a day regards jerk when driving the stalling when taking off happens only about once a week or fortnight. I have vcds and have run scans and no fault codes anywhere I have seen in previous post years ago of a fuel rail sensor issue but there are two sensors on the rail i did change the front one part No 04L 906 054 but it was 2nd hand maybe i should off bought new or maybe i got the wrong fuel rail sensor and that it is the other sensor on the end of the rail also I have start/ stop disabled so that cannot be the cause. Can someone help as I'm at my wits end as when in traffic at lights and about to take off the car cuts out i have to then put it in park and press the start button sometimes maybe twice. I dread that someone will drive int the back off me.
Nutz Posted May 30 Posted May 30 Hi Did you ever get this sorted out ? I’m having exactly the same problem?
Declanmc54 Posted June 5 Author Posted June 5 no never got it sorted I'm still driving it and it has got no better or worse
