dirolas Posted February 2, 2023 Share Posted February 2, 2023 Hello, Could this be from squeaking driveshaft bearing or ? Sound is noticable when speeding from 20 km/h and upwads So i went to a dealer, we changed the wheel bearing ( they were bad made sound front left and rear right ) , btw only 79k kilometers on my audi. Before wheel bearing replacement,i had some funny squeeking noise,which started from 20km/h while driving and it keeps squeeking if that makes sense. Could it be that it's driveshaft bearing out of order? Or "u" joint ? Propshaft part number 8W0521101 Anyone use this JXB driveshaft support carrier ? I will get the car to different workshop,if they confirm the same,than yeah,i will have to change it... Quote Link to comment Share on other sites More sharing options...
53willys Posted April 15, 2023 Share Posted April 15, 2023 Did you ever figure what was making this sound? My a4 is doing the exact same sound….it’s crazy because I can’t hear it outside the vehicle and depending on where you sit in the car depends on where the sound sounds like it’s coming from. Quote Link to comment Share on other sites More sharing options...
