archlee Posted 4 hours ago Posted 4 hours ago Hello I have an audi a6 2.0 tdi estate it has a handbrake fault on the rear drivers side so I bought a brand new caliper and pads and fitted them it still not working so I checked all relevant fuses still no joy I then bought a handbrake module and still nothing can anyone please help I definitely can't afford to take it to main dealers I'm defo at a dead end
spartacus 68 Posted 3 hours ago Posted 3 hours ago What’s the fault, what are the symptoms, is this an in-dash error. I take it you haven’t had the car scanned for fault codes? Manual or auto? The electronic parking brake is normally pretty robust. Rear calipers are known to seize, especially at this age, but you’ve already swapped it out. Are you getting 12v to the module? A cheap multi-meter is invaluable. Also check wiring there, especially the ABS wiring.
