Macky67 Posted 9 hours ago Posted 9 hours ago I bought the above in Feb this year,not my first Audi,with standard 17" alloys. One week later I put on a set of genuine 20" Rotors with correct tyre size ,profile etc. The next day a front spring snapped while parked up. I replaced both springs, since then I've had to replace both front bearings and driveshafts. All inside 2k miles. The car had 90k on it. So? Was this just mileage sensitive wear or have these wheels been the cause? Wheel alignment was done when fitting the bigger wheels. Just unlucky?
cliffcoggin Posted 7 hours ago Posted 7 hours ago I assume the large wheels will have very low profile tyres, an arrangement that is known to produce a much harsher ride than normal, so it's reasonable to believe that is what has knocked out springs and bearings. Not sure about the drive shafts.
