A6 software update and ami installation
Hi I've just purchased update only to find after day of stress I can't instal as DB activation can't be changed showing ?
Also how can I activate ami lead as not showing in mmi source selection
Thanks hope some one knows as I can't find answers on googlepost-1778-0-95338800-1375546779_thumb.jp
Have you purchased a genuine Audi DVD?  It needs activating at the Audi dealer with the codes on the inside of the booklet in the DVD case.
The AMI lead will only work if it has a blue collar near the and that plugs into the car.  If it is all black, it is for the early models and will not work with the MMI 3G system in your car.  Hope this helps.
Tech
Yes ami is conected blue cable yet nothing on menu sceen?? Thanks I'm guessing audi make a there money back somewhere down the line if you don't have options fitted.
There may be a problem with the AMI unit itself.  Is the AMI cable a new one, because they can be temperamental if they have been kinked at all.  I recommend you pop over to your local dealer and have a quick word, they may be able to just test a known good AMI cable for you before you look at an AMI fault.
I've had everything checked however still no ami showing in mmi 3G source selection only charging phone??
There must be a fault with the unit then, take it to the dealer
I did as it's not fitted by Audi they are not prepared to touch it.. Weird I know
It's not fitted at factory as standard they will not touch the car??
Crazy as I can't understand why audi won't touch a product they manufacture and supplied.
Audi Part numbers:
Diagnostic interface 4F0 035 909
iPod/iPhone Connection lead 5N0 035 554 B
AMI harness 7L6 035 727
Audi Part numbers:
Has it been coded properly into the MMI unit when it was retrofitted?  Its not just a plug and play situation installing AMI
Yes the garage sorted my problem within 10 minutes. Totally recommend this garage spot on service
David Coe Auto Engineering,
Cecil Road,
Gorseinon,
Swansea,
SA4 4BY
Telephone:01792 896653
Garage specialises in Vag.com / VCDS
He's even offered to set up more options.
Thirty minutes only cost £27 labour will call again to this garage. He even wanted to remap my engine where do I stop....
