edek71 Posted March 27, 2019 Share Posted March 27, 2019 Hi everyone, Your help on this one would be much appreciated, I need some expert or someone who has faced this issue in the past. I bought Audi A5 2014 2.0 with CVT Multitronic gearbox, the car was bought from the damage salvage auction and was fully repaired by me in my garage. Everything has been fixed successfully, however I experience a problem with the gearbox - the car just does not move when the gear is being put in place. - every gear selected is showing a neutral however you can hear the pump launching on and moving the oil. I have a VAGCom diagnostic software, tried connecting via OBD II and the car does not display any errors - all the errors have been removed after accident. I am blind on this one, is the gearbox in some sort of emergency mode after the accident, does it need coding/adapting? Maybe the oil has to be changed? Thank you very much for all the replies Quote Link to comment Share on other sites More sharing options...
Tam Posted August 5, 2020 Share Posted August 5, 2020 Hi, can I ask you if you got to the bottom of your problem, I’ve got a similar problem with the same motor,thanks. Quote Link to comment Share on other sites More sharing options...
