Help wipers stopped working
were woirking ok,i put em in service mode never worked again fuse under bonnet looks good.............plus these other fault codes too.
ALL WORKING NOW GUYS NO IDEA WHAT HAPPENED THOUGH.
Thursday,05,November,2020,18:27:45:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8V9F1030874   License Plate: AUDI S3
Mileage: 52892km-32865mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 26 42 44 52 55 5F A9
VIN: WAUZZZ8V9F1030874   Mileage: 52892km-32865miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1D00322426010B2000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E253C0380F232BB60F-806A
No fault code found.
Readiness: 1010 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4517
   Revision: 03252204    Serial number: TFK01405222244
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1BE18727385BB34B9-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 61484000000769
   Coding: 33F193A254232A6C017F070741C769CCC92A5480E08296F6024100F88608
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 45D753EFE5246163215-8010
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 E    HW: 8V0 820 043 E
   Component: AC Automat    H13 0052
   Revision: 20000700    Serial number: 00000000318011
   Coding: 05100004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 34311E2BBEBEE8EB86B-8060
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: 92F80137000000000001
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011414703366
   Coding: 07041C47C24106FD03204004B11807A80100000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005982FBBA86844B523-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140525  041 0585
   Serial number:         140528142132
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22708575
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Component: E1 - LDS MQB  H05 0032
   Serial number: 27 03 2014  00000946
   Sensor For Anti Theft Alarm System:
   Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY141050V64
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000029938502
   Neck Heating Left:
   Subsystem 6 - Part No SW: 8V7 963 579     HW: 8V7 963 579
   Component: KRH375 links  H14 0003
   Serial number:  P141562903702000159
   Neck Heating Right:
   Subsystem 7 - Part No SW: 8V7 963 579     HW: 8V7 963 579
   Component: KRH375 rechts  H14 0003
   Serial number:  P141562903702000158
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 167
                    Mileage: 52892 km
                    Date: 2020.11.05
                    Time: 17:29:09
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231415700035
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_VW37.rod
   VCID: 3B23351793E02793471-806E
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       290514002
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 41DF47FFF10C4D431DD-8014
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 A    HW: 5Q0 959 655 A
   Component: AirbagVW20    009 0865
   Serial number: 003ESR0098VY
   Coding: 98C0C0000000A0005C5000CA00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002136
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 206 14
   Component: SideSensor_Df  001 0887
   Serial number: 3570000000098AA4CF0/
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 14
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000008CAA4CF01
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 012 705 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01BF11ED23DBJ
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 804 14
   Component: FrontSensor_D  001 6149
   Serial number: 35500029B1524DC3111Z
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 06061404220247
   Coding: A018
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 7CA1F60BD66EE0AB0EB-8028
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 8V0 920 971 J    HW: 8V0 920 971 J
   Component: KOMBI         H02 4291
   Coding: 27AD100A3B8026000101E8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009040
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 44D14EEBEE1E586B36B-8010
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 28051410800736
   Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   VCID: 42DD48F3F40A565B047-8016
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Component: E221 - MFL  H02 0014
   Serial number: 26 05 2014  B0023932
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 6633083603
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00025.04.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46D554E3D8226A7B28F-8012
Address 26: Auto Roof (J256)       Labels:* None
   Part No SW: 8V7 959 255     HW: 8V7 959 255
   Component: VSG-AU375     H03 0030
   Coding: 400000
   ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
   ROD: EV_ElectRoofContrMAQAU37X.rod
   VCID: 08499ADB92B6BC0B1A3-805C
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 C    HW: 5Q0 959 593 B
   Component: TSG FS        020 0026
   Serial number: 26051403111326
   Coding: 00514E724009040000001402
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 C    HW: 5Q0 959 811 C
   Component: FOND_FHSG_DRV  002 0005
   Serial number: 00000000000002741924
   Coding: 0D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3537232FB5C4F1E3B15-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 C    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0026
   Serial number: 26051402091118
   Coding: 005146724C09040000001402
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 40D942FBFA06444B123-8014
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 C    HW: 5Q0 959 812 C
   Component: FOND_FHSG_PSG  002 0005
   Serial number: 00000000000002487634
   Coding: 150000
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 C    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: --------------
   Coding: 01A600002B230200
   ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB410787F83BB36B9-806A
   Led Headlamp Powermodule Left:
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00100
   Led Headlamp Powermodule Right:
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00100
   Left Headlamp Power Output Stage:
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7040
   Coding: E00100
   Right Headlamp Power Output Stage:
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7040
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 036 B    HW: 8V0 035 036 B
   Component: MU-H-LND-EU   H43 0356
   Serial number: A300E0EB001871
   Coding: 017305010000000021111102000A00102F00022701000100DC
   ASAM Dataset: EV_MUHig6C3HBAS 001040
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 313F173F41ACDDC3EDD-8064
   Data medium:
   Subsystem 1 - Part No SW: V03 959 800 PS    HW: -----------
   Component: ECE 2014/2015  --- 0086
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY2013ZS
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0766
   Serial number: C1000026031400020525
   Compact Disc Database:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1010
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140515201811
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 7DA7FB0FCD74E9A3395-8028
1 Fault Found:
0006 - Actuator for Structural Accoustics
          P193A 00 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 7
                    Reset counter: 127
                    Mileage: 52892 km
                    Date: 2020.11.05
                    Time: 16:47:51
End----(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
Edited by vw754
Problem fixed
Hello Mo,
You just filled up my computer memory with all this detail!
With respect to your heading of ‘Wipers not working’. Daft question, but was the bonnet properly shut?
Yes bonnet was closed, tried it twice, fuses good, no faults with vcds, then for some reason started working
Right then Mo - Many thanks for the short reply. ‘Fuses good...’ Does that equal you have removed/wiggled the fuse to check it? If so, this act may well have re-established good contacts. If this were mine, then I would be buying some contact cleaner and giving the fuse box a good spray followed by wiggling each fuse to ensure there are good contacts.
