Electric window switches - help!
Help. I have a Audi A4 2001 B6 and the driver side electric window switch has stopped working, the passenger side electric window switch is working though.
Also, rather annoyingly, the electric mirror control has also just stopped working. Can anyone suggest where I can find the switches? they seem harder to find than rocking horse poo.
Also, is this the cure? or should I be considering a different solution for my switch problem.
Thanks
Jake
  • 1 month later...
It sounds to me that the electrical connection between the car and the door is faulty if both your mirror and window have stopped working. and the passenger side still works,
Hope this helps
hi had same thing last week the wires that come from behind the dash and into the door you can see them when door is open big thick black sleave full of little wires all my wires had come apart bar 2 had to solder them back together now working fine
hope this helps
