Hi.
If I read correctly data sheets, then both models (55 and 60) use the same electric motor (same power). In EV only mode they behave the same - max 130kw of power (same 10s acceleration to 100kmh), but in combined mode the 55 version limits electric motor performance to caa 50kw. If above asumption is correct then there is only SW limitation, since the HW electronics needs to support max 130kw power in only EV mode?
