AUDI Q7 2008 4LB 3.0.Oil filter housing.
HI
Just wondering if anyone has come across while fixing an oil filter housing /oil cooler leak
Have stripped it down ordered new parts The oil filter housing gasket in the one i pulled out has some extra holes cut out,
new one has not. Do i need to cut out extra holes in new base gasket. Not sure why these holes were done. watched some you tube and
fitted new base gaskets domn have extra 2 holes. Vehicle is audi Q7 quattro 7/08 cas25453  3.o td
cheers
Any images of the two mating surfaces?
hi
here are photos one without gasket one with gasket in place also a couple photos of inlet manfold face. After cleaning found these indents obviously from the worn swirl flaps. Fair bit of play in end one qwhich must of been worn for a while to indent the faces. front indent reasonably deep, will check inlet manifold when i pull it apart to see any internal damage, or if i have to raise in dent slightly if required with maybe something like jb weld. Not at mating /sealing surface so should be ok
