Upper timing chain cover gasket/seals
Hey all,
I’ve got a small oil leak from the upper timing chain cover and have traced it back to the main seal.
I’ll be replacing the seals between the cam adjuster and cover, the main gasket, and the internal O-rings.
My questions are:
  • Do the cam adjuster bolts need to be torqued to around 9 Nm and the main cover to around 10 Nm, or is hand-tight sufficient?
  • I’m also unsure where exactly RTV sealant needs to be applied—any guidance on this?
Has anyone tackled this job before - car is an 2013, 2.0tfsi, ea888 gen 3 engine
Thanks,
Ravs
