Ricky Posted March 3, 2016 Share Posted March 3, 2016 Hi everyone. After living with the car for a couple of weeks now you notice things that need doing! Now I knew there was something up with the front soft close on both sides. My question is are they on a fuse/relay or when they stop is it a dead motor generally? There is no noise at all when the door just clicks in. If it is a dead motor is it a separate unit to the actual door lock itself? Also the exterior door handle lights. Should there be 2 lights under each handle? As I only have 1 on 3 handles and the drivers door no light at all. On my dad's 2010 S8 he has 2 per handle. I have plugged in my vcds but can't seem to find anything on either of these problems. I admit I'm not fully 100% with vcds yet but am learning! And lastly for now! The main headlights are to low, are they only adjustable through vcds? Thanks for reading Ricky. Quote Link to comment Share on other sites More sharing options...
James Posted March 4, 2016 Share Posted March 4, 2016 I think the soft close is a bit of a common problem on the A8/S8 and can be a snapped cable rather than a motor or anything. Not sure on the number of lights under each handle - is it not possible to see the individual bulbs using a mirror? Quote Link to comment Share on other sites More sharing options...
