Sat Nav and phone volume issues
Everj5
Hi,
Recently bought a 2007 q7. When I 1st start the car and put the sat nav on the sat nav volume is full. And when I 1st make a call through the car the caller volume is at minimum so I can't hear them. Once I adjust the volumes it works fine until I restart the car.
Any help is appreciated
Thanks
Might sound silly but when you get in the car does it remember your phone and connect automatically or do you have to pair it manually with the PIN number. I had a problem with mine in that it wouldn't store any of the settings for the handsfree after I turned the ignition off they just reverted back to what somebody had set them too years ago. I upgraded the software to 5570 using the discs but it made no difference. I was told it was a fault on the Bluetooth module and that it needed replacing so I just lived with pairing it everytime I got in. Mine was a 2006
