Newbie suspension question
Hi all
total newbie question, so I apologise
I have found so many forums and chats and struggling to find the exact answer I need
I want to lower my s5. 2009. I can't believe how high it is standard and want somthing a little more sporty as Audi "should" have made it.
im keeping the standard 19" alloys but want a lower look, but not too aggressive and not too low.
i can't decide between h&r 25mm or 35mm??
Can anyone help?
Will 25mm make any difference? Or will 35mm be too much?
https://www.ebay.co.uk/itm/231395293190
 https://www.ebay.co.uk/itm/291270852225
Thanks in advance
andy
isnt the s sitting on lowered 30mm sport springs. might be somthing to check out
Welcome to the forum Andrew :)
I think it all depends on how you drive and where you drive. For example in areas with a lot of speedhumps then 25mm would be better. Normally though 35mm is the norm and would give you a really good ride. Have you asked h&r? They should be able to advise you as what's best for your type of driving.
Hope iv helped :)
cheers
steve
