Common Faults *if any*
After recently purchasing the car stated in the description, i am just trying to find out of any known common faults with these cars? The only one iv come across so far was the glove box light switch.
1, I was confused and couldn't find the switch so searched google to find that it's hidden behind a panel on the passenger side.
2, The common fault is a plastic pin that wears pretty easily which connects the glove box lid to the switch. I checked the switch but there was no pin so I used a tiny bolt and put a nut on the end. Hopefully with it being metal it won't break and should last a long time.
3, I noticed that there isn't a fuse associated with the interior lights/glove box light/bootlight so also had to do some looking up on google. Found out that it's fuse 38 (15a) which was indeed blown. Replaced the fuse and bam, all the lights work again.
EDIT: The car is a 2002 plate
  • 1 year later...
Well, my car has 65,000 miles on it and we have had it since 07. We drive it like old dead people so we baby it to death.
Problems?
1) We have a convertible and our glass rear window has nearly completely separated itself from the fabric top which shows a lot of quality. =) Very common problem amongst a lot of cabriolet owners. Most use glue, dealership says just replace the entire top for an easy $5,000 ...... no thanks.
2) if the cars sits for more than 4 days without being started and then we start it the car kinda shakes and sounds like it is going to barely start. Not a starter or dead battery kinda issue but more like a "junky manufactured engine with assorted problems" kinda issue. Not sure if others have this. Same goes for days where it is very cold. We do synthetic oil changes every 5k miles and use 93 gasoline. But we had an Audi TT before and only had issues with that too so I am thinking it is an audi thing.
3) Our black plastic skid plate thingy fell off going down the highway, nice.
4) the window switches are kinda "sticky" and gummy ..... classy.
5) the black coating they used on the switch to lower the convertible top and for the headlights has begun to chip off ..... quality.
At about 45,000 miles something went bad with the car mechanically and they fixed it under warranty but it would have costed us $4,000 they said if we did not have the warranty. I forget what it was altogether.
This may be the last Audi we own, after having many issues with the TT we had and now having problems with our A4 at just 65,000 miles I can't see spending AUDI money for something with so many issues. We have owned Hondas and Toyotas that go for up to 250,000 miles and run perfect! My Dad has a Toyota truck with 175,000, he bought it new. Only has had to change oil & tires. Still runs and looks like new. Same goes for my Mom's Honda. She always kept it as a backup car since ti was paid for, now 250,000 miles and never once had any problems with it! oh well.....
