Rear ABS Speed Sensor bolt head rounded
Hullo,
I have a fault code on rear left speed sensor, tried to get it out and the bolt has already been rounded out! Its gonna be super hard to get a drill in there to drill bolt out. Is the only option to disconnect the the brakes and drive shaft and take out the whole rear suspension/swing arm thing? Any help/tips would be appreciated.
Cheers,
Long extension and a turbo reverse socket and a hammer.
Possibly an impact driver will help too.
Just hope the bolt doesn't snap! Then it's a strip down either way.
Happy snapping!
Cheers, thanks very much for that. I'll give it a go tommorow.
