D4 ?
Killzone
It's not impressive but a couple of points;
Your 2017 model was spec'd in 2010 - the new model was released in 2018
I'm guessing that you bought it second hand - so did you not check before you bought it?
There were also either 3 or 4 model options for the 2010-2017 A8.
2 hours ago, Killzone said:
It does, if I get the very bad vibration  rattles  from the rear shelf,  I may get the caraway upgrade,  the issue is so bad I will hand the keys  back if not sorted.
I'm not sure what you mean....
So you have a Universal Serial Bus connection via AMI?
Are you now talking about Undamped Shelf in Back ? 😁
If you're unhappy with the car then send it back - life's too short.
