B8 allroad load cover fitting
Good morning, just seeing if people have had the same issue as myself, I brought my 2011 allroad without a load cover for the boot, I've brought this one below and it doesn't seem to fit in the space, it seems too wide for the gaps, I've tried pushing the clips in either end, is there a difference between the normal avant and allroad boots or is there a different between the b8 and 8.5, or am I doing something wrong to get it to fit? Advice would be appreciatedimage.thumb.png.31109be44767cbacf04ceff487c15bd5.pngimage.thumb.jpeg.c0f198b71e326d08dba2418260a311e0.jpegimage.thumb.jpeg.e9b77ed8363d9bdd3df9ac5252f07038.jpegimage.thumb.jpeg.5db3db01ab670597ba5be3acd8c8812b.jpeg
Hi,
Looking at your pictures, i think I can see the problem,
they are a bit awkward to fit,
you have to put the left hand end in first  (it goes in at an angle)
then the other end should click into place.
hope this helps.
5 minutes ago, dalswinton said:
Hi,
hope this helps.   p.s. best take the net part down before u start.
1 hour ago, dalswinton said:
Hi mate, thanks your your reply, I've tried again and it just seems too wide to fit in both slots, I must be doing something wrong.
My next question is whether the allroad and normal avant have different connectors for the boot, I've been to my local audi dealer and they couldn't get it to fit
Hello, newby here, but did you know each end compresses inwards? They are spring loaded. They are wider in the relaxed state, but they are squeezed into the recesses.
hi,did you manage to sort the parcel shelf out.i have an audi a4 estate 2011 but my parcel shelf looks the same as yours. the width of mine is 124cms.i can add pics if needed please let me know
