Starting issue with audi a5
😁 i have a starting issue, when I push the key the car doesn't start it comes up with parking brake fault then start stop fault. After a few attempts,  which is getting worse it will start. Anyone had this problem and can help please
Hi unless changed recently it is probably the battery on its way out, other than that the easiest thing is to get it plugged in for faults and if they are low voltage faults thats your answer.
I have had this plugged into a reader at a garage and had no faults. If battery wouldn't other electrics become faulty. Thanks
