Engine light with error code U0029
Conrad668s
Hi,
Had my 2016 allroad for nearly 3 weeks and get occasional engine light with my cheap code reader displaying U0029
Regular mechanic can't get any further with his diagnostics and recommend taking to Audi.
Anyone had experience of this code?
Cruise control doesn't work and it won't do a regen on dpf either. Using loads of diesel.
Google says NoX sensor or canbus issue
On 11/3/2022 at 8:47 PM, Conrad668s said:
Hi,
Hi did you ever get to the bottom of this fault ?
I have same issue with a q7
defiantly a Nox sensor issue, that car cant talk to the sensor for whatever reason
The easy one is check the sensor is not dead after that you looking at checking the wiring unfortunately which is a right pain
