HELP - heater core replacement
On 7/2/2025 at 8:16 AM, Vytas said:
Hi Ian,
It`s in the 5th picture from the bottom in my guide as well.
Regards
Vytas
Hi Vytas, removing glove box o.k to do and does the pollen filter compartment need moved or anything?
I've been told that it's a ful dash removal for this heater core, clearly not
  • Replies 79
  • Views 47.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Hi,  I had very little knowledge or experience with cars, so the steps I mentioned earlier were as far as I could manage on my own. Fortunately, I found a mechanic who was able to assist. I’m not
  • So i have done the Heater core matrix change and it was not difficult without any mechanical knowledge, however would recommend to have someone to help you as at some stages it looks like you need ano
  • I originally had intermittent heat, this then became no heat. I just googled around to see what the issue could be. That pointed me to some coolant “bag” issues some people were having.  this relate
Posted Images
Hi letsok,
No, the filter stays. No need to remove the whole dash, only if you need to take the whole heater unit, not just the core.
Hi Vytas, thanks for the speedy reply. So is the Nissens brand dead on to use? I see Parts in motion only have 1 left in stock of the Mahle one but wondering if its made in china & its £98, where as the Nissens one i can get for £66.
So no more issues with the brand the you fitted?
Nissens is perfecrly fine. Good quality part. Just dont forget the new o ring seals.
  • 2 months later...
Hi Vytas, just another question about the A4 B9 heater core replacement. See when re-filling with new coolant after you've changed the core, did you use any special tools like a vacum filler to refill it & bleed it? Or did you just pour it in slowly & start the engine & idle for a few minutes?
Many thanks
