Fan belt tensioner issue
Hi new here thanks for having us.
Got an issue on our 2.0 litre A6 c7 auto 62 plate
The fan belt started fraying little rubber bits so had it changed also changed the tensioner as it as moving when in idle.
Now the new belt in a brand and tensioner down same thing so chewing the belt on sides.
Again removed then one one and replaced with gates tensioner and gates new belt and again
Two questions
1. Should  the tensioner Havel little play or should it should I say
2. Also if so then why is belt having little bits throughout being chewed
I saw a mates 17 place c7 facelift but his tensioner was not moving however looked little different
Or am I incorrect in assuming it's different.
On ours belts looks correctly aligned
plz see vid
thanks in advance for the help
Anyone? Plz
