Coolant Warning
Hello team, I'm experiencing this issue quite a time. When driving the coolant alarm goes on and flashes, this happens at random times.
The car does not overheat and the coolant level is normal.
I have changed the temperature sensors as I thought that was causing the issue but the problem remains.
Also there are no errors running a diagnostic check.
If someone knows anything I would appreciate it.
