MAC34 Posted 21 hours ago Posted 21 hours ago Hi, hoping someone can help. The front windscreen washers on my A6 are not working. No pump noise but the fuse is fine and the pump was changed. Can a fault with the bonnet catch cause such issues? Garage told me it could but I can't find anything anywhere about this as cause.
Magnet Posted 10 hours ago Posted 10 hours ago Hello Martin, Have you blown out all the lines with an around 30psi air line? Have you check that the washer reservoir is free from slimy sludge at the bottom, and that the pre pump filter gauze is clean? Have you confirmed the pump is receiving a 12 volt supply - or not? Regards, Gareth. 1
Chris James Posted 9 hours ago Posted 9 hours ago Good Morning Martin, Was the replacement pump a main dealer or aftermarket item? I only ask this question because I had the same issues with my S7 and the independent garage I took it to gave me the option of both, but did explain that aftermarket pumps can give up quite soon - maybe 12 months or possibly sooner after fitting depending on make As a consequence I opted for the main dealer pump and yes it was dearer, but not by a huge amount and its still working! Best of luck sorting it Chris 1
MAC34 Posted 9 hours ago Author Posted 9 hours ago It was an aftermarket pump. I took the car back when the same fault (no pump, no spray etc.) occurred within 1 month. The pump and pipes were all fine. They did nothing other than grease the bonnet catches. This fixed the problem for another few months but now the washers are again not working. The bonnet closure/contact has something to do with the issue but nothing on the www that confirms the fix (I.e. where the contacts are or if catch lubrication is the issue). I saw something reference the closure of the bonnet being key to the washers working but can now not find that reference again. I'd like to think dealerships would troubleshoot all potential root causes rather than just go with those that give them business.... but I have my doubts on that front.
Chris James Posted 9 hours ago Posted 9 hours ago With most issues I try to steer clear of dealerships (other than some parts obviously) and try to find independent specialists who know the cars like the back of their hands. They tend not to charge quite so much and are enthusiasts about their specialist mark. Do you have access to any in the Winchester area? If you have they maybe worth contacting instead of the dealers.
cliffcoggin Posted 7 hours ago Posted 7 hours ago Martin. Is it only the washers that do not work, or are the wipers also not working? I know that some Audis have a switch on the bonnet that interlocks the wipers to prevent damage? 1
Magnet Posted 1 hour ago Posted 1 hour ago Cliff raises an important question here Martin. I can see you have re visited since this question was raised, but we await your reply.
