Bassdon Posted Sunday at 05:04 PM Posted Sunday at 05:04 PM Hi all When I go and switch the ac on, both fans come on (which I believe is normal), but the housing seems loose and the whole car shakes when they're running. I've turned them by hand and bearings are smooth and they're not loose, apart from the slight cushioning that, again, I think is normal, when I press them towards the radiator. Please see video of them running. Thanks! 20250531_180006.mp4
cliffcoggin Posted Sunday at 05:47 PM Posted Sunday at 05:47 PM As you said, the housing is loose so it's likely the fans are hitting it or something else in the vicinity. The solution I would say is obvious.
cliffcoggin Posted Sunday at 09:40 PM Posted Sunday at 09:40 PM Does it really need to be spelled out?
