Hi New Member
Just wanted to say hi !!!
Am running a 2005 Audi A3 SE 1.9tdi with about 220,000mls and hoping to keep it running.
Am not the greatest mechanic so will need all the help i can get.
So far:
Bowden cable clips replaced for both front seats.
Puddle lights changed for nice Aliexpress ones.
Door window frame and mechanism changed.
Rear wheel bearing changed.
Front calipers and flexi changed.
Rear ABS sensor changed.
Rear calipers, flexis and pins replaced.
Fuel temp sensor changed.
Glovebox lamp switch mechanism fixed.
Drivers door card clips replaced.
Front door lock mechanisms replaced.
Lighter socket fixed.
Handbrake cable and guide changed.
Rear wiper mechanism cleaned and washer jet fixed.
Front wiper mechanism fixed as was seizing and grommets upgraded.
Number plate lights fixed.
Track rod end replaced.
Ball joints replaced.
Oil and filter change.
Air filter changed.
Cabin filter changed.
New Intercooler.
Turbo and oil feed line replaced.
Clutch master cylinder replaced.
Air vents mechanism fixed.
B pillar trim removed and repainted.
Done about 10,000mls so far.
