Ignition fault
Help my a3 tdi has fault, starts OK but speedo, rev counter , mileage heater plug light airbag & abs light stay on can anyone advise suggestions??
Solved by cliffcoggin
It's likely the instrument cluster has failed, a common fault on A3s. Companies such as ECU testing amongst others can usually repair it for less than £300. You will need to remove the cluster and post it to them.
  • 2 months later...
On 2/21/2026 at 6:44 PM, cliffcoggin said:
Was the reply of any help to you Steve, or did I waste my time writing it?
Thank you great suggestion cured the fault it was as you suggested the cluster 👍
this usually isnt lots of separate faults tbh 👍
on A3 TDI when speedo + rev + ABS + airbag all stuck on, its often CAN / power issue or ABS module not waking up
