A6 2018 C8 3.0tdi quattro drivers mirror indicator
Hi all, was on le shuttle yesterday coming home when I noticed my drivers mirror indicator must have had a stone hit it and broken an inch off, no damage to the mirror. Has anyone replaced one? Is it an easy job and where to get a replacement that is the correct whiteness without paying main dealer price? Tia
Part is called turn signal indicator. Right hand side is 4G5949102B. Double check that with main dealer based on your registration. Think it should be around £45. Avoid Temu or EBay.
https://www.lllparts.co.uk/catalogs/audi/RDW/A6/798/9/949/949000
To access, normally pop out glass, see if any screws, then prize mirror cap off, again using the trim tools, as usually clipped in. Unscrew the existing module, until electrics, and fit by reverse.
Can be more complicated if lane assist or camera fitted.
This is 2015 A6, so should be roughly the same. https://www.youtube.com/watch?v=Hqps2U43fzI
Edited by spartacus 68
Thanks fella 😊
Hi,
For what it's worth; I was lucky enough to have the Technology Pack on the A6 I bought, so I have the LED Matrix headlights and dynamic indicators on the front... I found some side (mirror) repeaters on eBay that were also 'dynamic' and had tinted plastic lenses so look black, like the rest of the car/mirror, until lit... And then the lights 'sweeps' outward in sequence like the indicators both front and rear.
Cost me £30 for the pair, fitting is exactly as listed above, and they're still good 5 years later.
Took the 'chinese knock-off gamble' and won, in this case.
Hope yours are as easy as mine were to fit.
Best Regards,
Tigger
