2006 3.2 A4 Oil usage
Hi, does anyone experience excessive oil usage? I don't have specifics but it does seem to use more than you would expect.
Thanks.
I think up to a litre in a 1000 miles is classed as normal with the long life oil?
Thanks I will keep an eye on the usage then and see how it goes.
Yeah you should be OK. Does that seem about how much you're using?
I really don't know if I'm honest but I will try to keep a check from now on.
Fair enough, I'm sure you will be OK just keep an eye on it
Yeah will do.....thanks
