regnills Posted July 9, 2016 Share Posted July 9, 2016 hi everyone, not been on in a while I changed my clutch yesterday to a smf. after everything back on started no problem. reversed off driveway and headed down the road. there was no power. at a steady speed the whole carstarted to judder quite bad. my question is do I have to have the ecu remapped or something the only other thing I can think of is that I have pulled/broken some wire which is my next check. thanks in advance for any help Ste Quote Link to comment Share on other sites More sharing options...
regnills Posted July 9, 2016 Author Share Posted July 9, 2016 ok bit of an update. couldnt find any broken or loose wires but the engine management light came on the codes read: stored codes P0299 - turbocharger/supercharger "A" underboost condition pending codes P0101 - mass or volume air flow "A" circuit range/performance P0299 - turbocharger/supercharger "A" underboost condition do you think this will be just the air flow metre if so how much does one of these cost Quote Link to comment Share on other sites More sharing options...
regnills Posted July 9, 2016 Author Share Posted July 9, 2016 sorted nothing to do with clutch, I hadn't connected a intake pipe correctly I was rushing last night trying to get things done before my dinner was ready 1 Quote Link to comment Share on other sites More sharing options...
Trevor Posted July 13, 2016 Share Posted July 13, 2016 Glad you've got it sorted now! Maybe that should be a new saying "never fix a car on an empty stomach" 1 Quote Link to comment Share on other sites More sharing options...
