Power to fuse
Hello, I am having a problem with my blowers, I don't seem to have power at the fuse and am lost as to were to look next any ideas thanks
Hi Guy...welcome to the forum
There may be another fuse controlling the interior fusebox and then power to the blower motor.
Sometimes the motor seizes and than can lead to blowing a fuse...check any underbonnet fuseboxes.
Let us know what you find.
Cheers   Trevor
I have power to all fuses but still none to blower.there's power to inlet side of control box that is fitted on side but none to blower itself.also readings don't change when adjusting blower speed .
Have had that checked and have power to unit but not to blower and when tested the reading did not change when altering blower speed which I was told should happen,am thinking may be main control unit in car but not sure
I believe the current (amps) will change with the blower speed but not the voltage.  I would pull the power feed fuse to the unit and test the resistance with a multimeter to see if it changes with blower speed settings.
Not sure how to do that but the reason I said the main control unit in car is because my air con has also backed up
Try this fix to see if it works for your car. Also, another area to check is where the plug attaches to the heater blower unit....switch the ignition on with the blower switched on and wiggle the plug and see if powers up, if so then it could be a loose connection on the terminals.
