geoffrey Posted August 4, 2021 Share Posted August 4, 2021 recieved my Hydra Maximus today and have used it . just have to say that opening the product i had trouble in opening the seals . the cap was difficult to remove and now the additive leaks when i use it . manufacturer problem, the seal was difficult to remove and the product now leaks when i use it. Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted August 4, 2021 Share Posted August 4, 2021 1 hour ago, geoffrey said: recieved my Hydra Maximus today and have used it . just have to say that opening the product i had trouble in opening the seals . the cap was difficult to remove and now the additive leaks when i use it . manufacturer problem, the seal was difficult to remove and the product now leaks when i use it. I normally find that if you remove the measuring cap and just poke a hole in the silver metal seal just slightly to one side, the side you intend to tilt when putting in tank that works well and it won't leak. Steve. Quote Link to comment Share on other sites More sharing options...
geoffrey Posted August 5, 2021 Share Posted August 5, 2021 got it, i will just pierce the silver caps with sharp object next time. Ken Quote Link to comment Share on other sites More sharing options...
