Oil Level Sensor Help
Alright guys,
Hope someone on here can help me with this problem I’ve been trying to solve as I’m really stuck.
So when it was snowing a few weeks back unfortunately I hit a mound of snow and it disconnected the oil level sensor plug…. Which was then dragged along the ground for about 20 miles before I had chance to look underneath properly.
Immediately after the plug was cracked but we managed to reconnect it and the warning light went out, but a couple days later it managed to fall out and completely destroyed itself.
I’ve so far bought another 3 pin Bosch plug from simtek and replaced it but this hasn’t rid the car of the warning light.
The engine is: 2.0 TDI BKD
The oil level sensor part number is: 6pr008079-003 9a900a4942.png
-          What is the colour correct colour wires for each pin?
-          Does this type of issue need you to have the bonnet close while you reconnect the plug?
-          Does anyone know the part number for the loom that connects to the oil level sensor as I suspect the wires might be damaged for being snagged around under the car
To make matters worse, when I first managed to get the car on the ramp for inspection the picture I took focused on my glove and I cannot distinguish which way I’m holding it
Any help would be appreciated!
Thanks
