Fan wont turn off when I've turned off the ignition
Just got an audi a3 2.0 tdi and when the ignition is off the fan doesnt turn off. I'm guessing itll kill my battery eventually. Can anyone help me please?
  • 1 month later...
What you're experiencing should be normal:- Is it the fan or the Coolant After-Run Pump? The Pump protects the Turbocharger by circulating Coolant after you've stopped driving. It should turn itself off automatically, a few minutes after your switch off the ignition. If the fan or pump keeps running forever, Scan for fault codes. Look closely at the electrical connections. Check the Relays.
