Hi
I am trying to find the heated rear window fuse but to no avail as not mentioned in manual..does anyone know where its located and which fuse.
Its a 2011 first generation Q5 2.0 TDI Quatro
Thanks in advance
Hello Carl,
Sorry I cant help you directly with the fuse location, particularly since you say the handbook doesn’t mention it. Strange.
Can I take it the HRW doesn’t work, and you want to check the fuse? If so, a common failure point is a break/damage to the rear screen element which can be checked for continuity with a meter.
Not sure if this helps, but....
