Ttrs mk2 oil on top/rear of bell housing
Hi anyone else had a oil leak under the airfilter box around the rear of bell housing (see pics)
When i start the car and rev i can't see it leaking from anywhere
Does not smell like gearbox fluid so i assume it's engine oil, only thing i can see is the vacuum pump nipple is a bit loose back and forward play but don't know if that would cause this mess
