Audi Q7 2006 door touch sensor part number
Hi all new to the site, I have a Q7 3.0tdi 4lb 2006 and I had the dreaded door touch sensor fault for abit now and wanted to get it sort but can’t seem to find the part number for mine? Wanted to get the parts before stripping the door apart any help would be great 👍🏻
thanks Chris
Hello Chris,
Apologies if I’ve got the wrong end of the stick, but generally, requests for part numbers are usually to assist in the purchase of secondhand or aftermarket  parts. If buying Audi parts, then obviously it’s as simple as asking for the part at your nearest dealer - part number not required.
In case it helps, you can get discount on genuine Audi parts via. mail order at Audi Parts Direct at Cardiff. - part of Mon Motors (were Cardiff Audi).
Hi Gareth
I’m after some after market sensors but can’t seem to find the ones for my year!!!
thanks Chris
Hello Chris,
Apologies if this dampens your quest, but there’s a fair amount of experience that points to aftermarket sensors being highly variable, quality wise.
I guess you have the discounted Audi price, but if you are still insistent on going down the aftermarket route, then the only make I would consider would be Bosch.
Hi Gareth
no I don’t have an Audi price for the sensor nor have I contacted them, I was just after the part number for the sensor to see which one it is, as I’ve seen online 2 types a 2 wire and 3 wire sensor and how to remove them. Didn’t want to strip the door down to see which one it was to then re build it and do it again when the part arrives
thanks Chris
