Temperature issue
Hello everyone, hope you’re well, I need help with my Audi a4 b5 1.8 non turbo. When the car is cold it starts good a works without problem, after the temperature goes 90 degrees and i push the acceleration pedal the engine shuts down and after that it barely starts. The car has installed even LPG system and it works better with that, but in Petrol i have problems the engine chokes. I have changed all ignition kit ( spark plugs, ignition coil and spark wires. Also changed petrol filter. I appreciate any idea. Thank you!
