Audi S3 8V Tuning, Wheel Stud Conversion?
Hello everyone.
I have a 2017 8V S3, with a 2.0 TFSI engine. I've ordered some aftermarket wheels, which I know the factory lugs aren't going to fit. Diameter of the head on the OEM bolts is too big. Knowing that I should purchase a set of longer bolts or convert to a wheel stud conversion kit.
There are three advantages of stud conversion:
1.They offer an easy way to align the wheel when mounting;
2.They allow for the safe use of different thickness wheel spacers;
3.It is compatible with both ball and conical seat lug nuts, which is suitable for most factory or aftermarket wheels.
(Quoted from: why-use-stud-conversion-kit-instead-of-wheel-bolts )
Compared to buying a new set of bolts, stud conversion seems to a better choice. It is easier for wheel mounting. I have already get annoyed of these bolts. Thinking the studs should solve the problem.
