Fuel pressure regulator 2010 tdi p106500 code
Hi all ,  my 2010 a4 tdi started to idle really rough, it's still driving 100% just the bad idle, I had it plugged in and code p106500 is coming up , problem is its only telling me its a fuel pressure regulator,  when I Google it there are x2 regulators , one on the rail and one on the pump, has anyone else had this problem and what was the outcome , thanks in advance and thanks for the ad 🙂
Hi I would hazard a guess its the fuel rail sensor as if it was the pump regulator it would be running all over the place when driving, apart from which the rail regulator is the easiest and cheapest to fix.
clean EGR  valve    bud
Thanks guys
ne  probs   bud
So , got a fuel pressure regulator there today , hopefully it'll sort it ,  the guy said it came out of a 2013 2.0 tdi passat,  says its exact same part ,  does anyone know if these just fit straight in or would they need coded in ? Thanks
Hi dont qote me but I think they are plug in and play if thats a whole rail you bought you only need the bit on the end, just get anew seal.
  • 1 year later...
Did you manage to get it fixed? Im having the same issue :( not sure if its the drv or the pump regulator. Thanks
  • 1 year later...
I’m having the same issues as well mine comes up with these codes. It’s an Audi A4 2010 (Diesel)
P123700 - Passive/sporadic - Fuel injector cyl. 1 open circuit
P123900 - Passive/sporadic - Fuel injector cyl. 3 open circuit
P124000 - Passive/sporadic - Fuel injector cyl. 4 open circuit
P123800 - Passive/sporadic - Fuel injector cyl. 2 open circuit
P106500 - Active/Static - Fuel Pressure regulation contour difference
